Re: Expander Module & TabletPC's ?? Message #2 Posted by Raymond Del Tondo on 14 May 2004, 9:28 p.m., in response to message #1 by Steve S
I'm not sure, but I'd say CE software wouldn't work under TabletXP, unless TXP has a CE compatibility mode, which I doubt.
As if this wouldn't be enough, most WinCE applications are written for a specific version of the OS, so mostly WinCE 2 apps won't run under CE 3, and CE 3 apps won't run under PocketPC 2003. For this bullsh*t you'll have to blame MS;-)
Aside from this, same suggestion as for Hugo:
The link below will lead you to a list of hp discussion forums for the 'normal' products, like inkjet printers, and PDAs.
http://forums.itrc.hp.com/
For WinCE / TXP software support, there are various MS related forums and newsgroups.
HTH,
Raymond
