Re: HP 15C Message #3 Posted by Vieira, Luiz C. (Brazil) on 14 May 2004, 6:02 p.m., in response to message #1 by R Eierman
Hi;
try this: (make sure to locate both [ON] and [.] keys)
- with the calculator switched to OFF, press and hold the [ON] key;
- while the [ON] key is held down, press and hold the [.] key;
- release the [ON] key first, then release the [.] key;
This sequence toggles between dot and comma anytime you want.
Cheers.
Luiz (Brazil)
Edited: 14 May 2004, 6:03 p.m.
