Re: Fast Discharging Batteries in HP11C Message #4 Posted by Randy Sloyer on 12 May 2004, 6:21 p.m., in response to message #1 by TomG
With all due respect to Tony, I've never seen a leaky battery backup capacitor. Easy enough to swap out but my money would be on a bad processor chip.
If you have the two chip version 11C, you're in luck as you can use the processor from a 12C. Any made in USA 12C will have the cpu you need (1LF5-0301). The later 1LM2-0001 will work as well.
If you have a later model (serial starts with 28), you might be out of luck as they changed to a single chip version (1LQ9-0321). They're rather rare and the only source would be from an identical age 11C.
