Charging Batteries Message #1 Posted by Wayne Stephens on 12 May 2004, 8:02 a.m.
An old, non-HP (gasp!) RPN calculator has recently come into my possession. It is powered by 3 "AA" sized rechargeable batteries wired in series. The output voltage for each battery is specified as 1.25 volts (They are brand new and I believe they are NimH?). There is about 3.8 volts present at the charging port when the calculator is turned off and the batteries are fully charged, which they were when I received the calculator.
The problem is, the original recharger unit was not with the calculator and the manual gives no information about it other than that it takes "about five hours" to reach full charge starting with dead batteries.
I have a bench-top variable voltage DC power supply which I intend to use to recharge the batteries. However, I do not have a lot of experience with rechargeable batteries (at least not beyond charging them with the original factory charger). Can someone who is more electrically/electronically astute than I recommend a charging voltage? The highest I have dared turn the power supply while connected to the charging port is 4.00 volts, but for all I know it will take a year to fully charge the batteries at that voltage. Is there a "rule of thumb" ratio of charging voltage to design output voltage? I just want to be able to fully charge the batteries without damaging them or the calculator.
Thanks in advance to any/all who can assist me with this.
Take care.
Wayne.
PS - The calculator is a National Semiconductor 4640 in truly outstanding condition (other than the missing battery charger).
