Re: HP 11c Message #3 Posted by Vieira, Luiz C. (Brazil) on 12 May 2004, 2:53 a.m., in response to message #2 by Stephan (CH)
Hi Dave, Stephan;
I agree with Stephan that it is a plausible solution. But if fresh, new batteries don't work, it's more likely that you have a bad contact (cold soldering) in one of the terminals of the R2D2 (RAM-ROM Display Driver), the big chip that drives the LCD segments and status indicators. I had many Voyagers I repaired with this problem. Cleaning terminals and fast resoldering (VERY fast) was, in all cases, the solution.
The only one I had troubles with was an earlier model with the LCD, IC's and electronic components built in in a separate unit with flex circuit. Battery leakage corroded part of the copper trails and the flex circuit was simply lost. but this is a rare case... (sorry, I didn't mean to let anyone down, just facts)
If Stephan's suggestion does not happen to succeed (I hope it does), opening the calculator and cleaning IC's terminals is the other solution. At least, there are possible solutions, right?
Best regards and success.
Luiz (Brazil)
