Re: Inprt with HP49G+ ??? Message #2 Posted by Raymond Del Tondo on 5 May 2004, 6:32 p.m., in response to message #1 by Robin
I think the version for the HP-48 doesn't work with the 49g/g+, mainly because the used RAM entries have moved from the 48 to the 49, and maybe the one or other system call address is different.
Did you take a look at www.hpcalc.org ?
Maybe there's a version for the 49g+...
However, I don't know if the IR port of the 49g+ is even compatible to the IR port of the HP-48.
Raymond
