digit group and radix separators Message #7 Posted by Cameron Paine on 3 May 2004, 8:27 p.m., in response to message #6 by Raul Lion
The 15C and 16C are similar in that respect.
The 16C had four functions "bound" to the On key: suspend/run, test ROM, test UI and separator swap. The last three were two-key functions. I plan to implement these but I'm not sure how best to simulate them.
My first thought was to ignore suspend/run (which is what File->Exit does) and make the other three functions two-click sequences. This opens the possibility of binding other functions to the On key--makiing it a bit like another shift key. One such function would be to swap between IEEE-745 and IBM decNum floating point arithmetic. Obviously such "extra" functions could be bound to menu items.
Several forum contributors have asked to have On shut the application down. That's not an unreasonable request. Consequently I am re-evaluating how I might use On in the final version.
Incidentally, I started using On as a shift key that gives me access to debug functions long before I had any menus. So until I rewrite that code, On is not available.
Cameron
