Re: HP 41C - Converting From Radians to Degrees Message #2 Posted by Ray on 27 Apr 2004, 1:40 p.m., in response to message #1 by Mark McLean
Execute DEG (keystrokes: XEQ, ALPHA, D, E, G, ALPHA), then it is in degrees (0..360).
Execute RAD in a similar way, then you are in radians mode (0...2pi).
Execute GRAD, and you are in that mode.
To convert between degree and radians, use R-D (from radians to degrees) and D-R (other direction).
If you want to have one of these instructions as one keystroke only, use key assingment instruction by using ASN instead of XEQ.
e.g. ASN, ALPHA, D, E, G, ALPHA, ENTER
Now the RAD function is placed on the ENTER key.
Ray
