Re: More thanks... Message #7 Posted by Hugh on 22 Apr 2004, 9:16 a.m., in response to message #6 by DougT
A ha! I can certainly find a use for you, Doug. I'm attempting to use as much knowledge as I can in aircraft instrumentation (since everything is made to be high contrast, reliable and useable). Also, the materials being used for construction come from the aerospace industry.
I have so far focused on using aluminum for the entire case, but I am also considering titanium (although it will most definitely be more expensive... probably just make it an option).
If you wouldn't mind reviewing some of the designs, it would be a big help! Also, some of the manufacturing processes being explored (high pressure water cutting, etc.) may be to your liking. Please join in. I encourage anyone to use what skills they possess to improve any aspect that your training lends itself to.
