Re: Exploded batteries Message #3 Posted by Steve S on 15 Apr 2004, 11:09 p.m., in response to message #1 by Lance Pierre
I agree with Randy, with one minor difference.
I once had the batteries in a rare type of remote control leak, coating the spings and metal contacts. Because I couldn't just replace the RC, I set off to restore it as best I could. I wrote to Duracell (I believe it was) and asked for their recommendation. They suggested a ~5% solution of boric acid in water, followed by a quick rinse with deionized (or distilled) water.
It turns out that the actual concentration of the boric acid solution isn't overly critical. I just mixed up an approximate guess at the concentration and IT WORKED LIKE A CHARM! The electrolyte was completely removed and the metal parts were left with only a slight amount of surface corrosion and discoloration.
I've not tried vinegar, so I have no opinion about it. But I can recommend the boric acid, it worked great!
PS If you have to wash the foam rubber pieces, be sure you rinse them well. Have a hair drier handy and use it to GENTLY Heat the washed are to accelerate the drying. Don't let it get too hot!!!
