Re: HP-41CV - problems Message #6 Posted by Vieira, Luiz C. (Brazil) on 7 Apr 2004, 2:41 p.m., in response to message #1 by Artur
Hi, Artur; (tudo certo?)
Have you checked if yours is a fullnut or a halfnut? Look at the image below:
Raymond's comments are very important. A simple reset may solve the problem. What worries me is the already exisiting [MEMORY LOST] message and the fact it is broken and shows unusual characters.
If your 41CV is a fullnut (earlier, "original" HP41 display), chances are you have a common bad contact between the small mainboard and the keyboard contacts. In most cases, a simple cleanning procedure is enough.
Tell us (ou me manda um e-mail) if you need extra advice.
Success.
Luiz (Brazil)
