Re: Help with 42S Programming Message #2 Posted by Vieira, Luiz C. (Brazil) on 2 Apr 2004, 4:33 p.m., in response to message #1 by Bill (Smithville, NJ)
Hi, Bill;
I think that you have at least two alternate methods. I'm just pointing them out now, and I can scratch some steps to perfrom them; just a matter of time right now.
First: consider using ordinary numbered registers instead of ALPHA ones; there is a memory issue (less memory), but the indexes should be restablished;
Second: create three [1×3] matrices: DB, WB and PS. Whenever you want to use one or another, you simply INDEX it and use [->] or [RCLEL] to recall their contents.
These are the ones I thought about for now. Others surely exist, and someone will probably post about it soon. If you need guidance:
lcvieira@quantica.com.br
Anyway, I'll be back in a couple of hours.
Success.
Luiz (Brazil)
