Re: HP41CX 24hour time format Message #2 Posted by Vieira, Luiz C. (Brazil) on 1 Apr 2004, 11:17 p.m., in response to message #1 by Mike
Hi, Mike;
first let's lead you to a litlle trip. Get one of your fingers ready to press [R/S] and execute: [SHIFT][CATALOG] 2 [R/S]
You must be fast pressing [R/S] as you immediately see[-TIME 2x ] where "x" may be some letter (firmware version; the "2" means CX-ROM). Keeping your attention to [R/S], now you press:[ENTER] [R/S] and you are ready to navigate through the Time Functions by using [SST] (single step) and [SHIFt][BST] (back step) keys.
The first function you should see is [ADATE ] that allows a value in the X-register to be appended to the ALPHA register current contents with a date format. Of course, this number must represent a valid data.
Press [SST] five times and you'll see [CLK12]; one [sST] more and you'll see [CLK24]. O.K., you have the correct spelling. Now, press [<-] key (left-arrow) and your display returns to current X-register.
To actually execute CLK24 you must press:
[XEQ][ALPHA] C L K {SHIFT] 2 [SHIFT] 4 [ALPHA]
If you look at the small label in the back of the calculator, you'll see that all numbers are shiftted related to their keys when the ALPHA mode is ON. If you are executing [ED], the ASCII-file editor, there is a way to "invoke" the number keyboard by simply "deactivating" ALPHA (i.e. pressing [ALPHA]).
I hope this helps for now. Let us know if you succeed.
Cheers.
Luiz (Brazil)
(Please, if something goes wrong, let me know; again, I wrote by heart... No calcs in hands right now)
