HP Forum Archive 14
IR wavelenghts
Message #1 Posted by Tizedes Csaba [Hungary] on 20 Mar 2004, 5:15 a.m.
know anybody, what is the main wavelenght of HP's IR ports? And where I can find some about the HP calc's communication methods?
Thank you! Csaba
Re: IR wavelenghts
Message #2 Posted by Andrés C. Rodríguez (Argentina) on 20 Mar 2004, 10:20 a.m.,
in response to message #1 by Tizedes Csaba [Hungary]
While the IR wavelenght (from an optical point of view) is not critical at all, the frequency and coding of the pulses certainly is. The first IR models used an HP proprietary format, sometimes refered to as "RedEye"; some newer units as the LX100/200 PC Palmtops used the standarized IRDA (which is similar to an IR asynchronous serial port).
An article about the RedEye protocol appeared in the HPJournal in 1987, I think it was mentioned here before many times, and certainly is part of the CD set from the Museum. In the Archives forum you will find many references, including an interesting article (around 2000)from Steve (Australia) who managed to receive the pulse stream from an HP calculator on a PC, by means of a phototransistor connected to the input of the PC sound card.
Re: IR wavelenghts
Message #3 Posted by David Smith on 20 Mar 2004, 12:37 p.m.,
Most IR LEDs from that time period emitted at 750-900 nm.
Re: IR wavelenghts
Message #4 Posted by James M. Prange on 20 Mar 2004, 4:42 p.m.,
You don't mention which models, but I guess that the IR I/O would be similar for most models, excepting the 49g+ using IrDA I/O. For "Serial IR" I/O, see http://www.hpcalc.org/details.php?id=1722 (plain text) or http://www.hpcalc.org/details.php?id=4741 (PDF). For "Red-Eye" output (used for printing), see http://www.hpcalc.org/details.php?id=4742.
James
Thanks for your answers! [No Text]
Message #5 Posted by Tizedes Csaba [Hungary] on 22 Mar 2004, 7:44 a.m.,
