Re: HP41 Emulator Application Card for HP48GX Message #5 Posted by Raymond Del Tondo on 15 Mar 2004, 5:43 p.m., in response to message #3 by Marc
as Matthias mentioned, there was a patch version of the card image which let the emulator software run and display on a GX.
Please note that this patched version is only a hack of a few critical reserved RAM addresses. You can start the emulator on a GX, and maybe do some calculations, but you won't be able to use most of the other features of the program, like advanced functions, menus, or FOCAL progams.
And, of course it uses fixed addresses. Therefore you'll have to store the patched version at the start of port 1 in the right order to even run...
Regarding INPRT: As some other posters mentioned, the information traffic is one-way: From the IR printer module of the HP-41 to the input IR diode of the HP-48...
Regarding availability: The patched/hacked version of the emulator software once was available on some bbs, or maybe one of the Goodies Disks, I'm not sure.
Raymond (blank stare) (Ok, this was something for the die-hards;-)
