Re: HP-65 card reader Message #4 Posted by Ernie Malaga on 14 Mar 2004, 4:42 p.m., in response to message #3 by Jon
You mention the "original Standard Pac," reading OK, but failing to write. If you're attempting to write on the pre-recorded cards, that's the reason for your problems: they are write-protected by having the top-left corner clipped off. Any card with the corner cut is so protected.
Also, make sure the W/PRGM-RUN switch is set to W/PRGM when you insert the card.
-Ernie
