Re: HP 48G Screen Problems Message #2 Posted by Ron Ross on 11 Mar 2004, 10:23 a.m., in response to message #1 by David
http://www.fixthatcalc.com/
You might try the above. But if it is ONLY a 48G, you might just buy another as they sell for about $50 on ebay. It also uses the same screen as the Hp38G and these sell really cheap ie often less than $20 on Ebay. The operation will probably leave a mared/messed up fron bezal/faceplate.
Again, I suggest just buying another as they are a pain to work with and results are spotty. The site above may be worthwhile if you have a GX.
I might also suggest the new 48GII. List is about $100 and it is much faster than the plain 48G. Actually it is a 49G+ with no extended RAM (still comes with 80K vs 32 on a 48G), no SD Card, and a half speed ARM CPU that emulates the original 49G. Still, it may be worth it over a $50 Hp48G. However if you just like the keyboard layout and use it as a number cruncher, get another 48G, as the keyboard of the older 48G series is much better than anything yet available today.
