Re: Forth on a 41-CX Message #9 Posted by Diego Diaz on 11 Mar 2004, 11:53 a.m., in response to message #8 by Ángel Martin
You're rigth Angel (as usual... ;-) Only CV's or C's with one or more memory modules can run FORTH 41.
I've burnt the images you sent me into a Clonix module and they now run OK. (Well, at least they show "OK_" in the display, I can't say much more without a manual... BTW, Does anyone have a "shareable" copy?? :-)
You need to have at least 80 free program register (i.e. size=239 on a clean CV) for you to get FORTH working, (XEQ FORTH) otherwise you'll find "TRY AGAIN" in the display. Once FORTH is running it remains in memory even after OFF/ON cycling.
The correspondig FORTH41.HEX file (to burn directly into Clonix flash ROM via IC-PROG) will be placed on-line during the weekend.
Best regards.
Diego
Edited: 11 Mar 2004, 3:29 p.m.
