Re: The DIGI pack (was: HP-16C...on a CX) Message #8 Posted by Giuseppe Marullo on 8 Mar 2004, 1:02 p.m., in response to message #7 by HrastProgrammer
Valentin, Massimo and Luiz,
thanks all for your answers. I already have the pdf mentioned by Valentin, I will take a closer look.
Actually, it seems to me that the biggest problem is input limitation on binary numbers, this is caused by the function that let you input different base numbers.
On binary, it is limited to 10 bits, using DEVELOPMENT ROM, I must suppose is the same using the Advantage (just tested with V41, it seems the same).
I have taken a peek at the pdf from Luiz and I must say it is impressive, but I don't know if it is a quick way to "build" a calculator emulator.
I mean, I need a easy way to input numbers, I am not sure how to bypass this limitation.
I was thinking in using ALPHA input, but I don't know how to input "1"s and "0"s without using the shift.
I begin to think that a MCODE routine is the only solution...
