Re: replacement for 41CV Message #5 Posted by Ron Ross on 25 Feb 2004, 4:29 p.m., in response to message #1 by Cloyd
Best is to buy another 41c series (depending upon your needs and desires).
The newer Hp33s would work as a general RPN scientific and keeping it small, reasonable and easy to get. Drawbacks of course are the poorer keyboard, modules you may have, and limited variables.
An older Hp48G might work well for you (or it might not as it is a graphics and considerably larger in size). It has everything a 41c series has except Hp-IB interface. It has a serial port and lots of programs available. Programming is in RPL (both better AND worse than your 41, many arguements both for and against, and all are valid). Still has the quality Hp feel and proper placed enter key. Also, fairly cheap to get though used via ebay.
An Hp11c might also serve you well, and these typically sell for a little over $100 via ebay. Bargain compared to other Hp's (for a low end scientific), but a true power Hp41c user would feel cramped.
A nice upgrade (if you don't need Hp-IB, timer, or some specialized module) would be an Hp42s. This has all the math features plus many, many more of the 41 series, is faster, easier on batteries, uses easier to find batteries and will take any program (aside from timer progs of the 41cx) of the 41c series. All have to be keyed in as that is the only input available.
The Hp42s is my favorite machine and I would like it better if it had the I/O of the 48G series. That said, I always have a 48G on my desk for a couple of reasons. It is expendable, it has tons of features, the most used by me, is its units conversions and solver.
If you do not use your scientific functions you could buy an Hp17Bii and get a real good RPN calculator with lots of potential (outside of trig functions). Has good statistics and a real easy to use solver. These are typically $50 or somewhat higher. Same general calculator as a 42s except a business calculator (but there is a good reason why a 42s gets $200 + vs $50 of the 17Bii).
Actually the solver on my 42s seems faster to me, but isn't quite as easy to set up. But once I enter the equation, I find the 42s to be much better to use.
Depends upon your real needs: If you need another 41, you will have to buy a 41. If you just need a vertical RPN pocket scientific, I suggest looking at a new 33s.
Hope all this helps.
