Re: hp Laserjet 4mv printer Message #2 Posted by Richard Garner on 24 Feb 2004, 11:48 a.m., in response to message #1 by Rodrigo
On the LaserJet 4si you just press the continue key on the printer and that forces it to print from the default tray.
Before you print you can change the paper type either in the page setup section of the program you are using or through the printer properties.
