Re: HP75 82718A Expansion Pod Message #2 Posted by Steven Kutoroff on 22 Feb 2004, 7:47 a.m., in response to message #1 by Johannes Mueller
I asked the same question under similar circumstances a few months ago.
The 75D sits on the pod and is attached to it on the sides by the plastic side assemblies. These are attached by 3 screws each, remove the 3 screws on each side (one side has two other screws to leave in place). The pod is connected to the 75D by a cable into an expansion bay. It is all easy to do.
Be prepared to loose all your memory, or keep the AC adapter connected.
Only problem is that the batteries are in the pod and you will not have a battery cover for the naked 75D.
The memory in the pod is very handy.
delete with 123
email is as above but replace the * z * with the proper symbol.
