Re: HP-41cx - 42s - Triangle Solutions Message #9 Posted by Wayne Stephens on 27 Feb 2004, 10:05 a.m., in response to message #8 by db(martinez,california)
I must have a different program. The triangle solution in my 42S is 219 lines long. It starts with a Menu and lets you use the softkeys to choose SSS, SAA, ASA, SAS or SSA triangle.
It then prompts for the three known values which the user must provide.
It then provides the solution as follows using the two line display: displays S1/A1, user hits R/S, displays S2/A2, user hits R/S, displays S3/A3, user hits R/S, displays Area/Original Menu.
It works very well, displays angles in HMS, and the only glitch I have seen is that sometimes it will display an angle as (##-1).5960 instead of ##.0000 when displaying "exact" angles.
Take care.
Wayne
