Re: HELP! I need Head Cleaning Card for HP41 Reader Message #2 Posted by David Smith on 15 Feb 2004, 3:08 p.m., in response to message #1 by Colin Lambert
Take a normal card, douse it with 91%+ isopropyl alcohol, stick it in the reader and and force it past the drive roller. Push/pull it in and out several times. Repeat a few times. Wait for alcohol to dry (a few hours) or blow it out with canned "air" (otherwise the roller will slip).
All this assumes that your drive roller has been rebuilt. If it is original, you will need to replace it first.
