Re: different hp-45 versions? Message #4 Posted by Andrés C. Rodríguez (Argentina) on 26 Jan 2004, 7:36 p.m., in response to message #1 by linter
On the firmware side, there were at least two variants of HP 45, which differed in the operand sequence for recall arithmetic.
For instance, if Register 1 contains a 5 and the X register contains a 3...
In some calculators, RCL - 1 gives 2 (i.e.: X - R1 -> 5 - 3)
In others, RCL - 1 gives -2 (i.e.: R1 - X -> 3 - 5)
The same change of order affects division, of course, there si no difference for addition and multiplication.
