Re: Raymond Del Tondo Speed module Message #2 Posted by Raymond Del Tondo on 21 Jan 2004, 3:33 p.m., in response to message #1 by Marc
With Speedup ENabled at turn-on, SPD is 2355408 Hz.
With Speedup DISabled, it shows about 3681728 Hz.
Yes, it shows less when Speedup is enabled, but it works faster. I think the speed is calculated like x MOD 4MHz .
Note that only the CPU is sped up, not the other onboard peripherals.
