Re: Question about 82143 printer battery pack Message #4 Posted by Tom Sherman on 7 Jan 2004, 6:37 p.m., in response to message #3 by Jim Creybohm
Jim,
You can get an AC adapter # 82059D on eBay for about $10.00. It is the standard 110 volt AC adapter for the HP-41, HP-71, and HP-75 equipment.
Australia uses 230 volts, so your adapter would not work in North America unless it has a voltage switch built into it, or unless you bought a step-up transformer for it, which would be more expensive than buying the 110 volt adapter.
The manual recommends that the printer not be run on the AC adapter unless a battery pack is installed.
Tom
