HPIL PC board: works but test keeps failing Message #1 Posted by Giuseppe Marullo on 6 Jan 2004, 10:56 p.m.
Hi all,
following the advice that the bus could be too fast, I got a 486DX33? and installed the whole stuff, and used a copy of TRANS41.
It worked, at least I understand so. I was able to dump whatever I wrote, programs back and forth, etc.
Just to be sure, I tried the test that should be part of the software that came with the board.
It failed, HPIL link is broken.
So now, I suspect that TRANS41 could work on the faster pc, but also other stuff could work.
I am waiting the enanched EMU41 program to test it on both machines.
Which is the fastest machine on which you were able to run the HP82973 board?
TIA,
Giuseppe Marullo
