HP Forum Archive 14
HP Portable Plus instead of HP-IL/PC card
Message #1 Posted by Emmanuel, France on 22 Dec 2003, 5:24 a.m.
The Portable Plus can replace an HP-IL/PC card.
It has a serial and hpil ports.
It's more common.
I tested (and tasted!) mine.
Special version of JFG's Emu41 , SDS-II and HPILLINK work fine.
However Cross71, LinkPlus and Trans41 crash the system.
Some idea?
To be continued...
Edited: 22 Dec 2003, 5:25 a.m.
Re: HP Portable Plus instead of HP-IL/PC card
Message #2 Posted by Raymond Del Tondo on 22 Dec 2003, 5:56 a.m.,
in response to message #1 by Emmanuel, France
Hi Emmanuel,
a 'normal' HP-110 should be sufficient for data transfer, since it has the same ports.
Is there a version of Emu41 for the 110, too?
Raymond
Message #3 Posted by J-F Garnier on 22 Dec 2003, 6:11 a.m.,
in response to message #2 by Raymond Del Tondo
Hi Raymond,
I guess that the 110 has a smaller display (16 lines instead of 25), doesn't it? Except this, Emu41 should run on it.
J-F
Message #4 Posted by Emmanuel, France on 22 Dec 2003, 7:01 a.m.,
Dear Raymond,
Yes it's enough but RAM disc and display aren't comfortable to my opinion.
Yours.
Emmanuel
Message #5 Posted by Jeff on 22 Dec 2003, 5:58 p.m.,
I would also like to try this EMU41 on the HP-110 Portable Plus. Can someone help me obtain a disc for the 9114A? Jeff
