ROM Images from your own programs (long) Message #1 Posted by Miki Mihajlovic on 21 Dec 2003, 8:13 p.m.
While ago I asked how to create a ROM image from your own FOCAL code and that
steered an intensive discussion with (for me) lot of great ideas. My goal was to
be able to create my own ROM image file from bunch of regular application
programs and put them into Clonix, once it becomes available. Nevertheless, even
for the use with 41C emulators one can keep the similar programs in a sort of
library without the need for additional file housekeeping on a PC and to save
the physical RAM space of the machine.
Although some people might prefer using (I am sure great) SDK41 and getting to
the bottom of the process involved and understanding page switching, optimizing
etc. myself not being a 'system' guy, I was looking for a simple and effective
way of creating these ROM images with tools available (for free) and without
spending too much time doing it. So I thought that I can share the workflow I
used with the rest of enthusiasts. I am sure that I will not be telling much to
the power users who frequent this forum but for the rest of us that need a bit
of help with these kinds of things it might be helpful.
First here is the list of things you need to have:
- EMU41 from J.F Garnier
- hp41uc from Leo Duran
- Eramco ES-41 ROM image. You can get it from Warren's (other great HP)site.
- If you are using V41 or want to burn images into Clonix you need some
kind of utility to convert BIN (packed format) files to ROM (unpacked) files. I
used bin2rom kindly provided by Diego Diaz (thanks Diego). I believe that SDS-II
by HP can do the same thing.
- Your FOCAL code on PC.
(1) If you have your code in TXT format compile it to RAW format using
hp41uc.
(2) Use all the RAW files to build a LIF file (system) since EMU41 can read
these through virtual HP-IL interface. Building a LIF file is easy by using:
hp41uc /r=.\dir\*.raw /l=HPIL.LIF
This will put all of your programs into a single file we here call HPIL.LIF (can
be any name) and create a proper FAT from file headers.
(3) Convert Eramco ES41L.ROM and ES41U.ROM to BIN files using clbin41
supplied with EMU41, then just merge these two BIN files into a single one (copy
/b es41l.bin+es41u.bin es41.bin) to simplify things in EMU41.INI.
(4) To setup EMU41.INI we can use the simplest configuration needed. This
comes default with EMU41 (which gives you 41CV). Here is the INI file I used:
[MODULES]
; page size filename
0 12 rom41cv.bin
6 4 prter2e.bin
7 4 hpil1h.bin
12 4 es41.bin
14 8 MLDLRAM.DAT
[DEVICES]
DISPLAY
HDRIVE1 HPIL.LIF
;FDRIVE1
DOSLINK
PRINTER
(5) Run EMU41 and issue DIR command. This will list all the files on LIF
filesystem. As a test case I used files from the Geometry solutions book so I
got something like this:
CIRTGNT
DISTLNS
VNOTCH
(6) Now, load all these into EMU41 RAM by specifying the file name in alpha
register eg. [ALPHA]CIRTGNT[ALPHA] and issuing XEQ "READP". Repeat for all the
file names from LIF filesystem. Keep track about the remaining free registers in
RAM, since they all might not fit in.
(7) Once you have them all in RAM, or as many as you can squeeze in you need
to initialize the RAM BOX. First clear it XEQ "CLRSU", and then initialize the
program block. To do that you will put the name for your future ROM IMAGE in
alpha register. This is the title name for the ROM image like "MATH 1C" or "STAT
1B". RAM BOX also needs to know which block (4k page number) you want your
programs to write to. Blocks correspond to expansion port numbers where lower
page has positive numbers and upper page has negative numbers. Since our
MLDLRAM.DAT file is defined to be in port 4 we have to use that number here. Put
it in X register and issue INIPRGM command. It will then ask you what XROM ID
number you want to assign to your ROM image. I used 18 (from plotter module
since I don't use it). To summarize:
[ALPHA]GEOMETRY 1A[ALPHA]
4
XEQ INIPRGM
018
(8) We are ready now to load programs into RAM box. It is a good idea that
you exit EMU41 at this point (by pressing F1 key) just to make sure it saves
your current status in case something freezes later.
(9) Programs are loaded into RSU by their global label names which are NOT
necessarily same as the file names from LIF filesystem. Easiest is to issue CAT
1 command and write down the global labels. Make sure the program pointer is in
the main memory, not in ROM by PACKING at this time. Load the programs by using LOADP command. It will ask for the program
name that you type in. I found it necessary to delete the program from main
memory (by CLP) after it was loaded to RSU. I am not sure why but if I didn't do
this EMU41 would freeze when loading the next program.
(10) The programs in RSU will have XROM 18,00; 18,01 etc. sequentially
assigned, no need to worry about that. Just have to make sure that we do not
have more than 64 global labels per single image.
(11) Once all the programs are in RSU exit EMU41 and rename the MLDLRAM.DAT
to MYROMFILE.BIN. To convert it to ROM image use the appropriate conversion
utility (bin2rom or SDS-II).
And that's it.
You can use HEPAX instead of Eramco to accomplish the same thing but my problem
with HEPAX was that it automatically assigns the XROM ID number to the image file
without allowing you a choice.
I am sure that this workflow is not a perfect one and that different, smarter
than me, people will improve it, but it works and it doesn't take a long to
package all your files into appropriate images.
Edited: 22 Dec 2003, 6:34 p.m.
