Re: 11c Power Supply Capacitor Message #3 Posted by Nelson M. Sicuro (Brazil) on 19 Dec 2003, 11:34 a.m., in response to message #1 by Lunn Sawyer
It is 22uF (micro-farad) x 10V (volts), the tolerance doesn't matter much, as is a "backup" capacitor (to preserve memory when changing batteries)
The capacitor voltage must be higher than 5V. You can find some 22uF x 6.3V or even 47uF x 6.3V (more time to change batteries) to replace it.
If you can get the tantalum ones, they are smaller and more durable.
Good luck!
Nelson
