Re: What are these pads for on the HP49G+ circuit board? Message #8 Posted by Veli-Pekka Nousiainen on 20 Dec 2003, 6:57 a.m., in response to message #6 by Nelson M. Sicuro (Brazil)
"Maybe these contacts are for JTAG programming/testing, just complementing what you said."
I finally opened my 49g+ and yes it is a JATG interface on the edge. I've seen that thing before. Maybe I will drill my case to open it from that point?
Opening: Above the backup battery are two white soft plastic rivets. I dug them out using a dull knife and pulled the top a little and then using a pensil as a lifter pulled the IR protector out with the knife. Next I used the knife to go carefully around the calculator removing the black frame. Then I just pulled from top (watching for the tension to the plastic) and the case started to snap open. There are two thin plastic rivets maybe on the cursor approximity that will brake during the operation. Shake them out and glue them into your collectors book (you have one/many - don't you?).
To take a good look inside you also need to loosen the piezo buzzer by gently pulling the tape covering the wires away from the case half.
Assembly is a snap. Do evrything in reverse order. The IR cover is thou good to put in before closing the cases.
Naturally you know how to ground yourself while handling CMOS circuitry!
[VPN]
