Re: HP 71B and the HP-IL Message #2 Posted by Terry Ingram on 12 Dec 2003, 4:27 p.m., in response to message #1 by William LaPier
Hello Bill,
You can issue "OFF IO" to suspend operation of the HP-IL loop.
There is a note on page 15 of the "HP-IL Interface Owner's Manual" regarding the delay.
"Note: if you want to use your HP-71 without connecting or turning on the HP-IL devices, you may have to wait 2 or 3 seconds after you press "ON" before the prompt turns on (only if the HP-IL interface is installed)"
Terry
