How to recover a screwed HP-41CY / RAMBOX-II. Fortunately it is working again ! Message #1 Posted by Werner on 7 Dec 2003, 12:08 p.m.
Hello dear HP41-RAMbox enthusiasts,
here I am back again, and I can tell you the for me very happy news that I succeeded to recover my HP-41CY !
(For those who are interested but do not know about what I am talking here, please refer to the Forum Archive, see http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv013.cgi?read=47069 )
I write this report because first I want to thank again all of you who helped and supported me by their answering posts in this Forum. So thank you again, Mike, Raymond, Christoph and Angel for your kind posts.
Secondly I want to share my experiences with you on RAMbox recovery in case that your one should run crazy one day, too. These are my first experiments with the W&W-RAMbox, so maybe these results are known by many of you, but maybe they can help others also not being so familiar with that device ... who knows ...
Sorry, if I should bore you by a too long text here ... ;-)
Every synthetic 41-programmer knows that after the HP41 froze or ran competely crazy due to some “ill code“ programming or some “not allowed“ experiments, it can at least be recovered by a Master Clear/Memory Lost. But this only addresses the RAM area and not the Q-ROM-area that is used for Mcode.
Unfortunately, the Q-ROM-Master-Clear of the RAMbox-II-OS is uncomplete and does not help the experimental Mcoder in some cases which easily can happen. What is missing in the RAMbox-II-OS is a “RAMbox Complete Master Clear“-routine that erases all pages of both banks, no matter if you are momentarily working in bank #1 or bank #2. The implemented routine only allows to erase the bank were you are just in (working-bank).
The best way to recover a crazy RAMbox-II will be to write an own Mcode-function that addresses the bank#2 area in a more general way than RAMbox-II-OS does. But before we will have such a new self-made Mcode function, here I want to tell you about a procedure that should always help to recover a HP41CY or RAMbox-II.
My RAMbox went crazy due to some conflict of the plugged-in HEPAX-RAM or the self-switching process of its ROM-pages. By this some “ill code“ was placed in some Q-ROM-area of the RAMbox-II. In general it is possible to work with both devices together, it gives you a full 32k-HEPAX-RAM without losing the 4k-space of the RAMbox-OS and with full HEPAX functionality. This full 32k-RAM can be addressed by, e.g., using only a 8k-Standard-HEPAX module or by a 16k-ZEPROM which only carries the four bank-switched pages of the HEPAX-ROM area. In general this works fine but only in some cases there may happen such a conflict I had to face.
Now the problem was the following: I was in RAMbox bank#1 (OS “A“ being active) and could erase all “ill code“ from bank#1. But I could not erase bank#2 because I did no longer have access via the function “PG<>“ and the RAMbox-OS “B“ was hidden. First I thought that it was deleted as I wrote in my former post at this Forum, but it was not, it was only hidden. I further had tried the function “PG10“ as Raymond also had proposed. That was a good idea to regain access to the RAMbox-OS “B“ because “PG01“ and “PG10“ have a bank- interleaved structure of the 8 Q-ROM-pages. Unfortunately also this function did no longer work and so I could not reactivate OS-„B“.
Now I used plug-in ROM modules in order to deactivate some of the underlying RAM-pages of the RAMbox. At every page were I had placed a ROM module, there the “ill code“ could no longer be active and disturb the system. By this it was indeed possible to regain access to the even pages (#8,#A,#C,#E) of bank#2 and thus to also the RAMbox-OS “B“. Since then I knew that OS “B“ had fortunately not been erased but only been hidden. But still I was not able to access the odd pages (#9,#B,#D,#F) of bank#2. The reason was still remaining “ill code“ at bank#2 which I could not delete neither by a RAMbox-Master-Clear nor by a hexeditor because I had no access to the “infected“ Q-ROM-area.
After a RAMbox-Master-Clear of the even pages of bank#2 I could at least remove all plug-in ROMs without losing again my even pages of bank#2.
Now “PG10“ was working again and I could use it to switch from OS-“A“ to OS-“B“. Back to OS-“A“ I could jump by using “PG<>“, but not in the other direction! The odd pages always showed the contents of bank#1, no matter if OS-“A“ or OS-“B“ was active.
As I was not able to mask the still remaining “ill code area“ by a plug-in ROM module, the “ill code“ could only be in page #9 of bank#2. The reason was that I could mask any page-pair #A&#B, #C&#D, #E&#F by using an 8k plug-in ROM or page #A,#C,#E by using a 4k ROM, but I could not mask pages #8 or #9, because then I would have hidden and deactivated the RAMbox-OS at page #8 which I had to use for the functions “PG<>“ and RAMbox-Master-Clear.
So, I copied the RAMbox-OS “A“ and “B“ into an even page (page#A) by “COPYROM“ of the HEPAX module. I had to choose an even page because only the even pages were accessible at bank#2 (see above) and the still not completely erased “ill“ bank#2 was the important one in this case. The built-in “COPYPG“ function of the RAMbox does not work here because there is a copyright-protection implemented by W&W that does not allow to copy their own OS. For those who do not have a HEPAX, please see “Appendix“ below for alternative solutions.
After I had copied the OS to page#A, I masked pages #8 and #9 by plugging a 8k ROM module into port 1. Using only a 4k-ROM module is no solution because it only masks the even page of a port, i.e. page #8 in this case. But still the “PG<>“ and “PG01“ functions were not working properly. What now ? Yes, the worst case scenario had happened to me, there was not only “active ill“ code in page #9 but also in other odd bank#2 pages. So I had to mask both, page #9 by the 8k ROM and page #D by another 8k ROM which I could identify to be the villain. Now everything was fine again, I could again use “PG01“, and “PG<>“ in all possible directions. I made a RAMbox Master Clear in bank#2, and by this the “ill“ code in page #9 was erased.
Of course the RAMbox Master Clear got stuck because I performed it from the copied clone in page #A which was not write-protected. But fortunately the erase process seems to begin with the lowest page addresses. So the “ill“ code in page #9 was erased first before the OS in page #A killed itself. If the method with the self-killing Master Clear had not worked, I would not have known what to further do. Using the HEX-Editor of the HEPAX, by which you can delete whole page blocks does not apply because it only “sees“ the plugged-in ROM modules which I still needed for masking the “ill“ code (if you removed the masking ROMs, the RAMbox switched back to bank#1 instantaneously, I checked that). The same problem applies for the RAMbox's own function "CLPG" which also cannot clear a RAMbox page which is momentarily deactivated by a ROM module.
After having pulled out (“cold“ pull out of course) the 8k-ROM in port 1 the HP41 was working again. I performed a second complete Master Clear from the write-protected OS and erased also the remaining “ill“ code in page #D.
Now I could remove all remaining plug-in modules and now, my HP41CY was fully functional again ..... puuuuh, you cannot imagine, I am glad ! :-))))))))))))
Appendix:
Concerning the COPYROM function:
As the HEPAX module is very expensive and also extremely difficult to find these days, I cannot recommend the HEPAX-solution for RAMbox recovery here without reservation, of course. For someone who only owns the RAMbox-II or HP41CY but no other MLDL device or ROM/EPROM with a copy-page function should do the following: Take the RAMbox-OS-image which you can get from other HP41 enthusiasts and change both 10-bit-words at ’nFFD’ and also at ’nFFE’ to any other value than 17 (hex). 17,17 means “WW“ (=23,23 dec, i.e. the 23rd alphabetic sign, that is “W“. Maybe it looks like my own name initials ;-) but sorry they are not ... unfortunately I was not involved in the development of this brilliant device HP41CY ... ;-))
A kind HP41 expert had given me this valuable indication. Thank you, #D (I am sure you can identify yourself ...), again for this valuable information! I did not want to name you here again as I do not know if you want so. I found out that you have to change both (hex17)-words, so not only the second one, if you want to copy the page.
After RAMbox OS image modification you can load it from IL mass media or via IL/PC-gateway to your HP41. Alternatively, you can load the “COPYROM“ function from another ROM image, i.e. from HEPAX-OS or Eramco-OS or others which are easily available for free in the web.
Then you can perform the same steps as I did with help of HEPAX.
I would have really been sad if my RAMbox would have been dead as it is so difficult to replace. I really also hope for the MLDL2000 of Meindert and for the CLONIX of Diego. These will be very helpful devices. I would like to use a CLONIX with bank-switching for hard-implementing the RAMbox-II-OS (“A“ at bank#1 and “B“ at bank#2). Then in principle one could also remove the internal buffer battery.
Last not least, let me again thank you very much for your helpful comments after my last post in the Forum where I had asked for help. This Forum is crowded by a really good community which I know for only one year since I revitalized my HP41 interest after about 15 years.
Best regards from Germany,
Werner
Edited: 12 Dec 2003, 2:43 a.m. after one or more responses were posted
