Re: Whether there are calculators, which can work on a frost? -20 oC, -40 oC (0..-40 F) Message #11 Posted by Bob on 4 Dec 2003, 12:27 p.m., in response to message #1 by Sergei Frolov
You could always just put it in your pocket, next to your body.
If that doesn't work, just put the calculator in a small open sided (for hand access) glass box or under a glass cake/cheese "bell". The sun should keep it above freezing and you can still see the display. A cloth could cover the opening until use. For those overcast days, just heat a dry rock or brick and wrap it in a towel and place it in the box with the calculator.
The keys are to maximize the reception and retention of solar incidence and to reduce or eliminate the convective effects of wind and movement.
By the way, if you have to worry about your LCD, how do you stand the temperatures yourself ?
