Re: HP11C - Delimitters Message #4 Posted by Nelson M. Sicuro (Brazil) on 2 Dec 2003, 1:37 p.m., in response to message #3 by Russ Prior
The HP-11C manual said:
"To change the radix/digit separator convention on your HP-11C, turn off the calculator, then hold down the [.] key, turn the calculator back on, and release the [.] key ([.]/ON)."
It will work unless the [.] key (decimal point) isn't working...
Best regards,
Nelson
