Dear Jeff,
Your HHP Portable Eprom is a 32K Eprom Box.
You can only have 4 size configurations:
4K (one 2764 for L8 & one 2732 for U2)
8K (one 2764 for L8 & one 2732 for U2)
16K (one 27128 for L8 & one 2732 for U2)
32K (one 27256 for L8 and one 2764 for U2)
2732, 2764, 27128 and 27256 are Eproms.
You have 2 DIP switches:
one for memory size & L8 chip type
one for port address
When you open your HHP-PE (remove the 4 screws on HP-41 side), you have something like that:
| ________ |
| | L8 | |
| |________| |
| |1 2 3 4 | |_______
| |1 2 3 4 | |
| ________ |
| | U2 | |
| |________| _______|
|______________|
The top DIP switch defines the memory size and L8 type of chip used as shown in the table below.
The bottom DIP switch defines the port address desired for the Eprom memory.
MEMORY SIZE L8 CHIP TYPE
SW 1 2 3 4
4K + + + + for 2764
8K - + + or 27128
16K - - +
32K - - - - for 27256
PORT ADDRESS
SW 1 2 3 4
port 1 - + + +
port 2 - + - +
port 3 - - + +
port 4 - - - -
SW for switch
+ for up
- for down
To be continued...
