Sort of work Message #4 Posted by Mike on 22 Nov 2003, 7:56 p.m., in response to message #3 by David Ramsey
I have 4 options to scan a document.
1) Text and Graphics (as image) (1 bit, 8 bit, 24 bit)
2) Text (as image) (1 bit, 8 bit, 24 bit)
3) Editable Text (8 bit, 24 bit)
4) Editable Text with Graphics (8 bit, 24 bit)
If I scan Text or Text and Graphics, as images, it won't put more than 1 scan into a document.
If I scan Editable Text or Editable Text with Graphics it does put multiple pages into the document.
Seems like the first two options should allow multiple pages as well. The reason I want to use the 1st two options is that it has a b/w option and images are much smaller. 3 and 4 only have options of 8 bit gray and 24 bit color.
Do you have options 1 and 2 and can you scan multiple pages into a document with those settings?
