Re: Strange HP48GX Undo behavior Message #2 Posted by James M. Prange on 21 Nov 2003, 8:27 p.m., in response to message #1 by GE (France)
I hope so. The first thing that the ENTER operation (either explicit or
implicit) does, assuming that last stack saves are enabled, is save a
copy of the current stack for use by the LeftShift STACK (last stack)
operation in the 48SX/S, or UNDO as it's labeled in the other RPL
calculators.
Note that by default, last stack saves, last command lines saves, and
last arguments saves are enabled, but they can be disabled by menu keys
in the LeftShift MODES MISC menu, and last argument saves can also be
disabled by setting flag -55. For the rest of this post, I'll assume that they're
all enabled.
Maybe a bit on explicit/implicit ENTER is in order. Pressing the ENTER
key is an explicit ENTER. When in "immediate entry" mode (both the ALG
and PRG indicators are absent from the status area), many keys, such as
+, SIN, or the CON menu key, do an ENTER operation before executing the
key or menu object; these are "implicit ENTERs".
Quote: 1. Type : {2 3} [Enter] 5 [Enter] CON [Enter] (UNDO) you get back
both parameters of CON.
In this first example, when the last ENTER was done, the 5 was already
on the stack in level 1, so it was in the saved last stack. CON was in
the command line, so the CON command line can be recovered by the
RightShift CMD (last command lines) operation. For that matter, up to
four last command lines are saved, so the {2 3} and 5 command lines can
also be recovered. You can use RightShift ARG (the LASTARG command) to
enter both arguments to CON, { 2 3 } and 5, into the stack.
Quote: 2. Type : {2 3} [Enter] 5 CON [Enter] (UNDO) you get back only {2
3}.
In this example, the 5 wasn't on the the stack yet when the last ENTER
was done; it was still in the command line followed by CON, so UNDO
wouldn't put it back on the stack. If you want to retrieve it, you can
use RightShift CMD to retrieve the command line 5 CON, or you can use
RightShift ARG (the LASTARG command) to enter both arguments to CON into
the stack.
In both of these cases, I take it that CON was typed into the command
line with the calculator in "program entry" mode (the PRG but not the
ALG indicator in the status area), so it didn't cause any implicit
ENTER; the last keypress of ENTER put it on the stack and caused it to
be executed.
If you had done:
LeftShift {} 2 SPC 3 CursorRight 5 ENTER MTH MATR MAKE CON
Then the { 2 3 } and 5 would be already on the stack before pressing the
CON menu key (which would cause an implicit ENTER), so would be
recovered by UNDO. {2 3}5 would be available as a last command line, and
{ 2 3 } and 5 would be entered into the stack by LASTARG. But since CON
was never on the command line, it can't be retrieved by the last command
lines operation.
If you had done:
LeftShift {} 2 SPC 3 CursorRight 5 MTH MATR MAKE CON
Then { 2 3 } and 5 wouldn't be on the stack yet when the implicit ENTER
caused by pressing the CON menu key was started, so they wouldn't be
recoverable by UNDO, but the {2 3}5 command line could be retrieved by
the last command lines operation, and the LASTARG command would enter
{ 2 3 } and 5 into the stack.
So your 48GX is behaving exactly as intended, and in my opinion, as long
as you understand it, it's a good design.
Regards, James
Edited: 21 Nov 2003, 8:38 p.m.
