HP49+. SD memory card Message #1 Posted by Hugh Wong on 20 Nov 2003, 3:41 p.m.
I got a 16MB SD memory card for my HP49+. I can copy all the "alg" objects on to it but cannot copy library files for the HP49 nor HP49 files created by an application program and if it copies, the file manager will show error and cannot purge the object unless I purge from command line ( such as:- :3: objectname purge). Besides, if I turn the HP49+ on and going into file manager, select SD, the hour glass comes up but will not read the SD Card, but if I slide the card out and re-insert it again, the HP49+ sees it right away.Any explanation of this problem ?
Hugh
