Re: Consider building a "jig" Message #10 Posted by Paul Brogger on 17 Nov 2003, 4:08 p.m., in response to message #9 by Nelson M. Sicuro (Brazil)
re: twisting the metal tabs too many times . . .
You might consider building a "jig" -- a fixture that holds the pieces together and applies enough pressure for testing, thereby avoiding metal fatigue.
Randy Sloyer, I think, uses one for work on Pioneers -- I assume something similar could be built for 48G's. It needs to stay clear of the display (so you can see what's going on), press the PCB without shorting traces together (insulate its points of contact), and apply even pressure throughout the PCB/LCD/keyboard contact area. Not easy, but not impossible. (Easy for ME to say!)
Anyway, it sounds as if such a device has helped Randy -- I suppose it might help you, if you do a lot of work on 48G's. (Just a suggestion . . . )
