Re: .raw to text Message #2 Posted by Mike (Stgt) on 17 Nov 2003, 11:03 a.m., in response to message #1 by karl gruber
What kind of text would you like? Only hex presentation or as a program listing? If hex is sufficient use TextPad and define suffix RAW as binary.
If you need a listing first look for such a tool (there is one for conversion/bar code/do everything from ... [sorry, my brain]). If you can't find such a tool, make one of your own: Take emu41 from JF Garnier, look for the ROM image of Extended IO, define the RAW file as input to virtual HP-IL device DOSLINK, read in 7 bytes a time and store them i a XM register file, convert it to a program file, read it to main memory and - here we go - print it.
Simple, isn't it? In a similar way I made yesterday a routine to convert OUTP output to a RAW file. Works.
Ciao.....Mike
