Re: early 15c vs. late 15c Message #4 Posted by jose goncalves (Brasil) on 16 Nov 2003, 7:12 p.m., in response to message #3 by David Brunell
Talking about cutting corners, is it possible that HP went through the same internal revision process of the 12C ? I remember that the first 12C had 3 chips, then only 2 and then only one, even before Kinpo. The LCD assembly went through a major revision also.
I donīt have that many 15C to disassemble and check and, for sure, the 15C didnīt last that long in production, anyway.
