Re: 48GX stack too big? Message #3 Posted by Victor Koechli on 12 Nov 2003, 11:21 a.m., in response to message #2 by Randy
If you'd limit the stack size, the consequences for the calculator would be fatal. The stack you see in the display is *the* RPL system data stack, used troughout the machine by all RPL routines, internal and user made. If you'd limit its size to e.g. 4, like it has been suggested many times, you couldn't even add 1 to (2x-y) anymore, because internally, symbolics are taken apart ("exploded") into meta-objects and then reassembled. Thus, everything in the HP 18/28/48/49 depends on an infinite stack. It's an essential part of the RPL system.
Just hit CLEAR (CLR on the 48SX) or the DEL key once in a while, or whenever you're done with some calculation, and you'll be fine. Alternatively, you could install HPSauce which always displays the stack depth in the status line... ;-)
Cheers, Victor
