Help with HP-97S needed Message #1 Posted by Holger Weihe on 8 Nov 2003, 2:57 a.m.
yesterday I got an HP-97S. :-) Unfortunately I can't get it to work. When the power is connected, the Low-power-LED goes on. When I additionally insert a battery-pack, the LED goes out again. (The battery isn't good, but my other HP-97 works fine with it).
Switching the calculator on causes a short flash of a zero (or similar) at the last digit. After that nothing else happens.
Is this behaviour known to anyone of you? Where can I start? I took the calculator apart and cleaned the contacts of the switches etc, but that didn't help. Could it be a problem of the connector pins between Mainboard and Keyboard part?
Another thing:
The HP-97S came with a plastic device (seller called it HP-Console) that holds the calc and the Interface box. The main screws of calc and box are longer than normal to fix them with the console. Is this console a standard HP part?
Thanks!
Holger
