HP-IL mass storage Message #1 Posted by Pavel Korensky on 6 Nov 2003, 3:39 p.m.
today I got (free of charge) another HP82161A tape unit.
The unit is not working. Maybe, something is wrong with the motor, because the tape is not moving and the rewind does not work. I did not have time to test it yet.
But I got one idea. If the HP-IL part is working, it should be possible to build some kind of mass storage and put it inside the 82161A plastic case.
I was thinking about some microcontroller (ATMega or maybe SC-12) and MMC card or CF card. The card connector assembly can be glued to the cassette door (for simple media exchange).
Anybody tried to do something similar ?
The second possibility, how to use the HP-IL components is to build something like HP-IL/USB or HP-IL/Ethernet convertor and use PC with USB or Ethernet for connection to the HP-IL system. The PC can simulate the mass storage, printer, etc.
