HP Forum Archive 13
rom fix for 49G
Message #1 Posted by Eric Lundgren on 16 Oct 2003, 2:04 p.m.
Recently a post showed up regarding the adjustablity of the time in which the 49g records a key press, I believe the function is "KEYTIME". I have checked my rom version and it was the latest official release from HP, since my 49g isn't in front of me, I will guess and say 1.18. Here's the procedure I tried:
1. Clear stack. 2. Introduce the desired value to the stack, I tried 500. 3. Key in 'KEYTIME', including the ' marks.
When this didn't seem to work, I tried : 500-> 'keytime', and other variants. Will someone please point out the correct variant that I must have missed? Or is this feature only on the unofficial 1.19 rom?
Eric
Re: rom fix for 49G
Message #2 Posted by Veli-Pekka Nousiainen on 16 Oct 2003, 2:58 p.m.,
in response to message #1 by Eric Lundgren
How about using it from the CATalog? The command to set the value is ->KEYTIME. You will find it more easily (while in the CATalog) by pressing [Right-Shift] [ 0 ], which says -> in red.
