HP Forum Archive 13
HP49G Connectivity
Message #1 Posted by Neil Strickland on 14 Oct 2003, 6:55 a.m.
Dear All, My HP 49G displays the message "Awaiting Server Cmd" but the PC connectivity kit(ver 3.0r4 running on Windows XP Pro) fails to "Connect to the Calculator" and "Get calculator information". The lower pane on the PC connectivity kit screen just displays "double click to try to connect" and I get the same errors above when I try to do so. I am able to print screen dumps from the calculator to the PC so I know the connection is okay. Has anyone got any suggestions?
Regards, Neil
Re: HP49G Connectivity
Message #2 Posted by Victor Koechli on 14 Oct 2003, 7:27 a.m.,
in response to message #1 by Neil Strickland
Make sure the port settings (speed, baud rate, parity etc) are the same as on your HP and that you select the correct port.
Cheers, Victor
Message #3 Posted by Neil Strickland on 14 Oct 2003, 7:41 a.m.,
in response to message #2 by Victor Koechli
Thanks. I am using kermit and all the settings on the calculator (port, translation, baud and checksum) match those on the PC conn kit. Parity is set to "none", checksum=3, etc. Still no luck...
Neil
Message #4 Posted by Iqbal on 14 Oct 2003, 11:35 a.m.,
in response to message #3 by Neil Strickland
Where it says "Connect using" , select HPx9G+ option. Select from file if you want to download or upload. Type filename in box. The rest would be displayed on box tat comes up. Good luck.
Message #5 Posted by Veli-Pekka Nousiainen on 14 Oct 2003, 12:10 p.m.,
in response to message #4 by Iqbal
"Where it says "Connect using" , select HPx9G+ option. Select from file if you want to download or upload. Type filename in box. The rest would be displayed on box tat comes up. Good luck."
Where did he say "hp 49g+"???
Message #6 Posted by Neil Strickland on 14 Oct 2003, 6:05 p.m.,
in response to message #5 by Veli-Pekka Nousiainen
No, its definitely not a HP49G+.
Message #7 Posted by Brandon Del Bel on 14 Oct 2003, 6:53 p.m.,
in response to message #6 by Neil Strickland
same thing happened to me, but I think my home-made cable finally broke (I made it rather quickly).
Message #8 Posted by Iqbal on 14 Oct 2003, 11:35 a.m.,
Message #9 Posted by Veli-Pekka Nousiainen on 14 Oct 2003, 12:10 p.m.,
in response to message #8 by Iqbal
Message #10 Posted by Neil Strickland on 14 Oct 2003, 6:05 p.m.,
in response to message #9 by Veli-Pekka Nousiainen
Message #11 Posted by Brandon Del Bel on 14 Oct 2003, 6:53 p.m.,
in response to message #10 by Neil Strickland
Press DEL when your PC booting...
Message #12 Posted by Tizedes Csaba on 14 Oct 2003, 1:26 p.m.,
...then check, that port is setted to 'Enabled', what you tried to use!
Good luck!
Csaba
Re: Press DEL when your PC booting...
Message #13 Posted by Iqbal on 14 Oct 2003, 2:13 p.m.,
in response to message #12 by Tizedes Csaba
OOPs sorry.
Message #14 Posted by James M. Prange on 14 Oct 2003, 8:27 p.m.,
I've occasionally had this happen. Doing a "Restart" on MS Windows 98SE always seems to get it working again for me. I'm not positive, but I think that connecting to the calculator with HyperTerminal (and then disconnecting HyperTerminal) has fixed it too. I'm guessing that for some reason MS Windows "thinks" that that COM port is already in use.
Message #15 Posted by Neil Strickland on 15 Oct 2003, 8:05 a.m.,
in response to message #14 by James M. Prange
Thanks guys, I still can't work out why I can do a calculator screen dump to the PC yet it tells me it has failed to connect. I'm obviously doing something wrong. I will persevere (or perish trying!!)
Message #16 Posted by Victor Koechli on 16 Oct 2003, 7:24 a.m.,
I've tried the new version (3.04) in the meantime, it works without any problems with both my HP 48G+ and 49G.
Some thoughts to consider:
- Make sure that the COM port your calculator is connected to is actually enabled, as suggested by Tizedes Csaba.
- Make sure the COM port you're thinking of is the one you're actually using. I know it sounds silly, but maybe you think you're on port 1 when it's actually port 2.
- Check if any other application (e.g. fax software or the program to make screen shots from your HP) is using that port, preventing HPComm from using it. If so, disable them and try again.
- Make sure you actually use Kermit. Start the server on you HP by pressing and holding right-shift, then pressing right arrow. On my 1.19-5 ROM, not holding right-shift when pressing right arrow starts the Xmodem server instead. It should say 'Awaiting server command' in the display.
- Check if translation (Newline) and checksum (3) settings are the same as in HPComm.
- Delete any IOPAR variables sticking around to revert to the calculators defaults, and move to the home diretory before starting the server.
Hmmm.. can't think of any more right now. Tell us if you succeed. Good luck!
Cheers, Victor
One more thing..
Message #17 Posted by Victor Koechli on 16 Oct 2003, 7:30 a.m.,
in response to message #16 by Victor Koechli
.. just crossed my eyes: On HP's website there is no mentioning of Win XP, just older versions up to 2000. Maybe someone else can comment on this? I'm using 2000 myself, which obviously works OK.
Cheers, Victor
Re: One more thing..
Message #18 Posted by Arnold Steekelenburg on 16 Oct 2003, 8:32 a.m.,
in response to message #17 by Victor Koechli
I have no problems whatsoever using win XP Home Edition.
Message #19 Posted by Veli-Pekka Nousiainen on 16 Oct 2003, 11:15 a.m.,
in response to message #18 by Arnold Steekelenburg
I have no problems whatsoever using win XP Pro Edition.
Message #20 Posted by Victor Koechli on 16 Oct 2003, 7:58 p.m.,
in response to message #19 by Veli-Pekka Nousiainen
You are right, of course. With a little searching an clicking you can find a 'Windoes XP compatibility statement' on HP's website. HPComm for HP 48/49 is said to be fully compatible.
Neil, any news?
Cheers, Victor
No news is good news
Message #21 Posted by Neil Strickland on 16 Oct 2003, 10:52 p.m.,
in response to message #20 by Victor Koechli
Not in this case... No luck as yet but I will try out your earlier suggestions. I really appreciate everyone's input. Neil
HP 49G Connectivity
Message #22 Posted by Neil Strickland on 19 Oct 2003, 4:14 a.m.,
in response to message #21 by Neil Strickland
Still no luck. One thing I noticed is that the Calculator Communications Settings dialogue box shows a HP48 and its grayed-out so it can't be changed to a 49. Is that a generic setting for both the 48 and 49?
