Re: HP15C 'Stuck' in User Mode Message #2 Posted by bill platt on 6 Oct 2003, 6:09 p.m., in response to message #1 by Melody
Hi Melody,
First, check to see if either of the keys have problems---so try "f" with any other key and make sure it works, e.g. f prefix should clear a prefix, and also show the full "mantissa". And check the RCL key: does it recall a register? If both keys work fine, I would then run a self-check and see what comes up--and then clear the machine if need be (following the manual's instructions).
Good luck and best regards,
Bill
