Re: 49G+ Equation Library Message #4 Posted by Ed Look on 2 Oct 2003, 12:43 a.m., in response to message #3 by r. d. bärtschiger.
Uh, this is sort of terrible... a website statement says there is one, then there is a blank table in the calculator itself under the heading of such a library!
Hopefully, it is not a flash update that one has to buy!
But I have two personal views on this and I hope not to offend anyone:
1. The 48G series equation library I understand is compatible and can be downloaded into a 49G/G+.
2. Do any of us really use (often enough, anyway) such a library? If it concerns your interests, you'd probably know it well enough not even to require a book for reference, and if it's something you'd use once in a while, it may not be too much trouble to key in the equation into the table yourself!
Comments?
